Girth Rubs Log Out | Topics | Search
Horse driving trials forum » Archive » General - 2012-15 » Girth Rubs « Previous Next »
Daniel Snow
Username: Snowd
Post Number: 53
Posted on Sunday, 19 July, 2015 - 11:58 pm:
Not an expert but I don't think the girth should rub at all. It should not be tight like a riding saddle girth. I think it should also be placed slightly further back.
It might help if you could post a photo of your harness when put to.
Kayti & Daisy
Username: Clarrion73
Post Number: 7
Posted on Sunday, 19 July, 2015 - 9:41 pm:
I was suspicious of this when I got my zilco classic, so I changed to a longer girth, from the cob to a full so it ended higher up her sides, away from armpits. Has worked for us :-)
Vicky Brennan
Username: Vicky_brennan
Post Number: 75
Posted on Saturday, 18 July, 2015 - 11:21 pm:
What Fiona said .... I had this problem too - solved it by setting the saddle slightly further back and doing up the over girth a hole looser ... most of the pads take up more room and seem to make it worse?
Rita Bundock
Username: Roanmare
Post Number: 61
Posted on Friday, 17 July, 2015 - 11:50 am:
You need to harden the skin to prevent this from happening again. Old fashioned method but it works - apply surgical spirit to the area (NOT when it is red raw, horse will go throught the roof if you do!!) a couple of times a day for a few days.
Fiona Powell
Username: Fionap
Post Number: 367
Posted on Friday, 17 July, 2015 - 6:57 am:
Hi, Donna, what works best for this for me is to fit the harness pad slightly further back to avoid it happening again and to use a short girth sleeve at the sore place. (A section of a soft thick towelling sock works if you haven't got a girth sleeve.)
I'm sure others will have more ideas.
Best of luck! Fiona
Donna Daynes
Username: Donnatellos
Posted on Thursday, 16 July, 2015 - 9:31 pm:
My Girth has rubbed a couple of sores in my horses armpit. Is there anything I can put on the girth to stop this happening. I have a Zilco Classic harness.
