How would you put padding on a pairs ... Log Out | Topics | Search
Horse driving trials forum » Archive » General - 2011-12 » How would you put padding on a pairs pole? « Previous Next »
Joe Hodgson
Username: Joehodgson
Post Number: 12
Posted on Friday, 18 February, 2011 - 5:45 pm:
Ha ha sorry i do mean foam.
Margaret Brockie
Username: Margaretb
Posted on Friday, 18 February, 2011 - 5:36 pm:
Poor foal. It might be a bit thick but that is no way to introduce a youngster to driving. The RSPCA might have something to say!!!!!!!
Joe Hodgson
Post Number: 11
Posted on Friday, 18 February, 2011 - 4:06 pm:
cheers for that Fiona
What i have done is got thick foal wrapped it around the pole and then wrapped it with duck tape and it looks super. It's only for my own use at home not competing in pairs yet anyways as only got going last yr in pre-novice..
Fiona Powell
Username: Fionap
Post Number: 8
Posted on Tuesday, 15 February, 2011 - 8:02 pm:
Hi, Joe, you can buy padding with a nice vinyl cover and a zip. Probably any carriage supplier would be able to help you...
This is what I did!
I got some not-too-squashy foam - about 2" thick or so - and wrapped it round the pole, securing it with cable ties, making sure any hard sticking-out bits were facing the ground.
Then I sewed a long tube of medium to heavyweight upholstery vinyl and made a hem at one end and threaded a shoe lace through it. Just fold over and hem the other end to make it stronger.
Then put cover on pole like a giant sock and tie the lace at the front end so it looks neat.
Remember to make the pole cover long enough that you can lengthen the pole for dressage and shorten it or fit a different head for the marathon (if you do).
I found that putting a "sock" of Lycra on over the foam makes it smoother and easier to change the vinyl. If you are feeling posh, make a cover for every-day use and another for best!
If you want a cover for the spring end, I copied my old one before it fell apart, again making it with foam and upholstery vinyl and securing it with Velcro.
If you use Velcro, make sure you use the widest sort - about 1.5" and stitch it really well on to the vinyl as otherwise it comes apart, in my experience.
Let me know how you get on?
Joe Hodgson
Post Number: 10
Posted on Tuesday, 15 February, 2011 - 5:25 pm:
Or
Can you buy the padding to fit poles
